BOXHEADgumby
I’ve been searching for turn signal issues like mine and I haven’t seen one.
has anyone who’s swapped their stock instrument cluster out for a year one set up with new auto meter gauges had their signals stop working?
I swapped mine and since then my signals only go solid, the same for the hazards. They worked prior to the cluster swap.
I see on the my mopar diagram that the indicators go through the circle pin connector , do they have any effect on the signal loop? That’s my assumption is that something there is my issue or I just made a gremlin come out of hiding while moving stuff around.
