dustya_383
I'm using the center force dual friction clutch and was reading in Mopar muscle that when using a diaphragm style clutch there is no need for the large spring on the clutch pedal assembly. My question is , is the centeforce df a diaphragm style clutch ? Also what is the difference between diaphragm and any otter types of clutches and should I remove the spring or keep it?? Thanks vehicle is 74 duster
