Can someone explain when to run a single pattern cam vs a dual pattern cam? How do they differ in power production?
That's a fantastic cam too. The good old Road Runner cam.1967 383 with the 516 closed chamber heads, 10:1 cr. 4bbl.
This is a prime example of a dual pattern factory camshaft because the exhaust valves are very small and need more duration to stay open longer than the larger intake to help expell the exhaust gases with the small exhaust valve.
325 factory Horse Power.That's a fantastic cam too. The good old Road Runner cam.
And how much torque? What? How much? Uh huh. 425 LB FT. ....and people say the 383 is a dog. I will admit though, I like Comp's version of the Road Runner cam better. Tighter LSA and ground for .903 lifter diameter.325 factory Horse Power.
Yeah for sound.So would a thumper cam with a much wider duration variation work better than a typical split pattern cam with just a 6 or 8 degree split?
The sound is more so due to the narrow (numerically low) LSA.So would a thumper cam with a much wider duration variation work better than a typical split pattern cam with just a 6 or 8 degree split?
That’s me. But he said explain. Now that’s tough.
Dont let the dilemma keep u up at night get a proven grind and enjoy your Hot Rod.Thanks for all the replies. Still learning. Never too old!
Is there a way to determine the opening & closing events on Lunati cams? Lunati doesn't provide them.I run a SFT lunati voodoo with 1.6 rockers in my 340 with open headers and extensions. Car pulls to 7K at the stripe in good air.
Voodoo Solid Flat Tappet Cam - Chrysler 273-360 272/280
I agree. It's splittin hairs at best.Dont let the dilemma keep u up at night get a proven grind and enjoy your Hot Rod.
