cchrishefish
I am getting ready to install a new style Chrysler distributor in my 1964 Dodge Dart 225. I would like to buy a modern distributor hold down. Does anyone know where I can buy one?
www.slantsix.org/forum/viewtopic.php?t=37342&postdays=0&postorder=asc&highlight=distributor+holddown&start=0
I learn something everyday....
use mine...see the red?Your link is not working
Super, I would like the round newer style. PM me to discuss terms.I have some of the plates that mound to the distrib.
Do any other members have a simple solution to this problem? Halifax hops has the round distributor mount and has offered it to me, what can I do for the fork problem?The 'claw' part that bolts to the block is longer than a small block claw. The mounting place on the block is a little different as well for this style mount. Something can be made to work, but it will not be a simple affair, even if you have the slant six claw. The later 'claw style' does not directly fit the earlier style blocks but the earlier style mounts will work on any block because the bolt hole on the block is in the same place. I have pictures somewhere of the differences. I have a 79 block that was made for the claw style mounts and I prefer that style for the ease of timing adjustments (greater range).
The new Doug Dutra book, page 128, suggests using the late model hold down clamp if you can get one. So is the doctor correct?I wonder if you can cut the original one to work as a hold down. Hmm
So, I guess I am out of luck? Ok then, when I install my new distributor, I guess I need to use the old bracket. It will be easy to adjust the underside of the bracket witht he distributor off. So, I have to ask, should the underside bolt be adjusted in the center of the slot? I am going to install the new distributor when the engine is at 10 degrees BTDC, as mentioned in the new Doug Dutra book. This is the static method according to the Doctor.This picture shows how the later clamps fit on the later blocks. If you look closely, you will see the small ledge cast into the block for the claw to rest on. The older blocks (I am uncertain when this started) do not have the ledge and will need some provision to apply leverage or pressure to the distributor ring to effectively hold everything snug.
I am wondering why the Doug Dutra book suggested this without going into detail?This picture shows how the later clamps fit on the later blocks. If you look closely, you will see the small ledge cast into the block for the claw to rest on. The older blocks (I am uncertain when this started) do not have the ledge and will need some provision to apply leverage or pressure to the distributor ring to effectively hold everything snug.
or buy the special slant 6 distributor wrench, no longer available, to make the adjustment.
