Hyper_pak
Old School Chrysler Fan
I was going to mention the Mallory Double Life and Dual Point subject, but it looks like you guys caught that while I was asleep last night.
Easy, rob. Set the points put an ohmeter/ continuity check on it and see if it makes and breaks. You can rig a drill, etc to check dwell out of the car, might even do so spinning it by hand You can also check rotor phasing. Open up an old cap so you can see one or two towers and then with a continuity checker on the points, slowly and carefully turn dist so points break. You should be able to easily see rotor relationship. I would pump down vacuum can, if you are using it, to make sure rotor stays within "range" as the vacuum moves it's range.Well, if the double life works with one set making and breaking separately of the other, is there a reason this slant six distributor won't? I guess the only way to find out is finish it out, stick a rotor and cap on it put a ballast, coil and one plug wire and a plug and see if it'll fire. Crapped if I know.
By the way I have a new in box "dual" electronic distributor like used on the late 70's, what you called it!!? You know,the electronic setup that was prone to fail!!! (New and cheap $30). Or trade for donuts. Would such have any application for you distributor hot rodders??
Yes Lean Burn!!!! I had a brain fart!Lean burn. Only trouble is, they don't have a mechanical advance mechanism. I would be willing to bet you could Frankenstein one in it.
Being only 6 lobes I'd think you could get more dwell time out of each set of points vs a V8.
My question would be with equal centrifugal and vacuum advance what would you gain vs a good electronic ignition setup? Especially in an A body you'd have 2x the PITA setting up a points distributor, not a real abundance of space down there anyway on that side of the engine to fart with 1 set of points let alone 2 sets.
It's the other way around. "Dwell time" is points closed time and that is when the coil saturates---with DC current. But it DOES have to be open long enough for the spark to happen. And open is when the spark happens Only way I'd know how to do that would be to put it on a scope with a working coil and "simulated" plug gaps and see what it looks like. Actually you likely only need one gap........just run the coil wire to a plug and "scope" that. You'd want to check it at simulated idle, and expected max RPM, bearing in mind that's half crank RPM so spinning the dist. 3K is likely all you needI don't think there's really any way to make this work without moving something. Both points are only open for a very, very short time, so I don't see how the coil could get saturated. I'm sure they're open less than 10 degrees. Maybe less than 5.
Need something turns that fast? How about an angle head buffer or grinder?
What offset degree did you figure you needed?Both sets are making according to the meter and breaking for a short time according to the meter.
By the way you don't have to have an igntion scope to see, if you have or know someone has "just about any" oscilloscope, you can wrap a few turns of insulated wire around the coil wire and observe the pattern. Trigger it off the points just like a tach
Bear in mind you need a "good condenser" to make it work right
Sorry........any sort of oscilloscope.......ignition scope, electronics bench scope, it does not have to be "much a one." Any electronics hobbyiest/ ham operators in your 'hood?
What this will do is allow you to see if the "open" time is enough to capture the energy that "should be" in the spark
Here's a quickie I searched off the internet
Notice that the plug fires showing as a horizontal line. The plug is "pulling down" the voltage because of conditions in the cylinder. Then they show "coil oscillations." These are the last of the dying energy of the coil AFTER the plug has pulled down and loaded down the coil so much that it just won't "jump" anymore, and not the coil is "petering out. FROM THAT POINT to "points closed" which in this is labled "control module again allows primary current to flow" that is the same as "points closing."
WHAT YOU WOULD WANT is to make certain that there is "some space" in that area as shown in this example........in other words if the points do not stay open long enough, they might close again BEFORE the plug has stopped firing----thus robbing the firing cylinder of possible spark energy. The point to the far right is at the same time as the point at the left whichs says "secondary voltage building." That is the point at "points open"
RE-read the bottom Rob I managed to "doctor" the drawing maybe that's better LOL
I say run the one set of points under that wiz bang cap with the funny connectors and mums the word on how it works. 6 lobe distributor has more than enough time to saturate the coil between events..or just run an adapted Vertex 6. Set you back more than your motors machine work alone.
