C chargers777 Well-Known Member Joined Apr 21, 2007 Messages 91 Reaction score 0 Dec 31, 2011 #1 1980 from an od truck.will the truck flywheel bolt on to a v8?is the slant 6 truck flywheel same as a 318 truck flywheel?
805moparkid Slant and AFX Guy Joined Oct 29, 2008 Messages 11,498 Reaction score 282 Location Anthem AZ Dec 31, 2011 #2 no... slants have one bolt on the crank off from a small block... now if you want to go to the time to drill and then weld the old hole up you can...
