chinze57
Push Button tranny and a Slant 6 that'll never die
I've developed an oil leak recently. After I've parked it, there's always a few drops of oil on the ground. Around the valve cover/valve cover gasket seems dry. Judging from opening the hood to see, it seems to be around where the transmission and engine join together. Anything in particular I should look for? The oil drain plug is nice and tight.
