I just had to shorten a couple of the wires for the distributor and oil sender. Everything else was fine. I also re-used the starter, alternator, and voltage regulator. I purchased a distributor conversion kit so I installled the new ECU and ballast, but did not need to re-wire the harness, just used the existing wiring.
I am using a Eldebrock carb with an electric choke. The old wire that was going to the /6 "choke" was hot when the ignition is on, so I just re-used it to provide power for the electric choke.
You should not have any problems at all, but if you do just post it here and someone will help you out.
Have fun.
