slant 6 to SB throttle-how to do?
65 Valiant
Germany
Hi folks,
small tech question:
65 Valiant ex slant 6 4 speed car. Now gets a 360 with a quick fuel carb.
Can i use my stock gas pedal with its linkage and what about the old style slant 6 carb linkage!?
Who knows what to use and where to get the parts!?
thx a lot for answer.
JAN
If you have the twist linkage setup(like a '64 automatic slant does), the easiest way to convert is to buy the cable pedal setup from a v8 and bolt it in. You may need the firewall plate as well. Does it have the pushrod or the twist linkage?
Here is my actual pedal linkage...
so i have to swap into a V8 style??
has someone the needed parts? pictures??
thx
Try find early V8 throttle pedal, that would be easiest. You need to drill bolt and cable holes to firewall, they are already located there.
