Hammer
So I've come to the conclusion that rebuilding my busted 5.7L hemi and resto-modding into my 71 demon is out of my price range. So I'm back at my worn out, ole' six banger. I decided to get the /6 rebuilt but also upgrade it. I found a turbo from a mazda 4 cylinder that will do nicely for this build. I'm kinda thinkin that forged pistons are almost NOT an option. I could run boost without em and just set it conservatively; but why do that(except price). So basically the plan is to get the engine rebuilt with the stock rods and crank but upgrade the pistons. Then get a custom grind cam shaft made(or buy an aftermarket; depends on prices), and get my exhaust manifold modifeid for the turbo. Will be running a intercooler, but haven't decided on one yet. As far as head work; not too much. Probably upgrade the valves but idk. I'm using just a iron 2bbl intake I already have acquired with a demon 2bbl 350 cfm w/electric choke. And yes, I know about the oil/coolant lines I need. But that's later on. So anyway...I'll be dropping the engine off this week and would like to get this info out to you all to get feedback. A few questions off the top of my head for you slant 6 hotrodders; what's a realistic hp goal for this build? Is over 300hp unrealistic? I plan on running 93 octane and having the pistons ground out to lower compression. So I'm shooting for 10+ psi of boost. And also, any good questions I should ask my machinist before I start buying parts? Just hot me back ya'll!! I want to know what you all think bout this beast.
