Slant Power!
805moparkid
Slant and AFX Guy
Anthem AZ
so i did some number running on the wallace calcs and it looks like im running about 200 to 220 hp wheel depending on which on i use...
1/4 ET 14.72
1/4 MPH 93.59
Weight 3180lbs
Elevation 2000ft (speedworld AZ)
Temp 80* (probably higher)
humidity less than 5% lol
HP Calculator [FONT=Arial, Helv]ET (1/4): [/FONT] [FONT=Arial, Helv]MPH (1/4): [/FONT] [FONT=Arial, Helv]Weight : [/FONT] (in pounds) [FONT=Arial, Helv]Elevation : [/FONT] (in feet) [FONT=Arial, Helv]Temperature (F): [/FONT] (in Degrees) [FONT=Arial, Helv]Relative Humidity (%): [/FONT] [FONT=Arial, Helv]Fuel Type: [/FONT] Gasoline
Alcohol
[FONT=Arial, Helv]Power Type: [/FONT] Naturally Aspirated
Supercharged
Your HP is 219 from your ET
Your HP is 226 from your MPH
Your HP Correction Factor is 1.11
Your Grains of water is 8
Your DA (Density Altitude) is 3,793 feet
Your Altitude Density Index is 89.4 percent w
and my times should drop once i get some real tires that can hook up before the 60 ft mark! lol
60' in the 2.15-2.17 range right now with alot of spinning
My last slant I built ran a 9.89 in the 1/8 !!! I was pleased as punch to say the least !!!Never run it on a 1/4 mi track though !!
If everything goes as not planned,I'm hoping to better those times !!:headbang::headbang:
our all stock 1 barrel/through the exhaust best so far is 19.52
here we are racing @ mason-dixon with the slant six org crew....
Uploaded with ImageShack.us
that freaked me out lol! i thought that was my car!!
i got my slant down to a 18.35 @ 7x mph (on the original 300K one barrel motor)... i dropped a .5 second by just dropping the t-bars almost to the stops...
with the K1/weisco set up you better! if not you have to give them to me and i'll make them work!
ask madmax/6 about the valve reliefs in those... there wrong... so clay the pistons...
what trans do u run..do u run a deep pan. we r having that talk on slant six org.
running a 904 with T action manual reverse (non-low band apply), 3400 Edge 9.5" converter, stock sump pan with external big cooler
want to do a low gear set kit in it...
