Slant six/ 4 speed clutch fork
Princess Valiant
A.K.A. Rainy Day Auto
Colorado
Does anyone know what is the correct clutch fork for a slant six to 4 speed with the "027" bellhousing?
I'm guessing a standard slant six fork will work but I want to be sure before I get this transmission in the car and possibly have to pull it again.
I don't know if there is a difference between the OD version and the regular one, but I have one for slant to OD. What do you need off of it?
Depending on year of bell housing the early cast iron 027 that is the early bell? it used the small slant six clutch fork and the slant six z-bar needs to be used with it to get the correct movement on the release bearing. The later Overdrive bell housings used the longer V8 clutch fork.
Are you asking about a regular 4-speed or an OD 4-speed?
The OD is longer and regular 4 speed
The one I need Is from a 9.5 inch bellhousing. So any slant six with the standard bell OR 273 when the cast iron 9.5 inch bell was used.
