[SOLD] Slant Six Final Parts Sale
MidnightSwinger
Woodland CA
This is the last of my slant six stash:
2x Mopar Performance Steel Shim Head Gaskets part #2843182 includes two cork valve cover gaskets $65 for all.
2x starter shields $20 for both
12 used spark plug tubes and about 24 tube seals. Hard to find. $50 for all
Distributor splash shield, no broken tabs. $10
12 rocker arm adjusters $10
Distributor gear $12
Spare set of MSD plug wires that are mostly cut/assembled for the slant. With a bunch of extra boots and pieces $30
3 NOS caps with copper contacts, the two airtex caps include rotors. Assortment of NGK slant six spark plugs all for $35
2x Real Gaskets Water Pump gaskets $15
HEI plate and wiring. Heat sink plate mounts under the distributor, using existing drain holes. Wiring harness makes for a clean install. $45
Or take it all for $200 plus shipping
Located in Woodland CA 95695
