CichliDart
Well, where is it now?
Hello Fabo people,
I have what I believe is a 76 or newer Supersix engine in my 1971 Swinger. I went to time it one day last year and discovered after I loosened the distributor that the bolt on the bottom of the distributor was not tight. Which kind of explained why I would have ample power then kind of doggy at some points. Anyway I think I need to start over on timing this thing. I don't have a Factory Service manual for a supersix car so I am hoping you guys can set me straight.
Where should I set or tighten the bottom bolt? In the middle of the adjustment plate area? Then align the Distributor with number 1, and try to start it and time it?
I have had a slant before but the bolt on the bottom was never loose.
Thanks and sorry if I am not describing this clearly.
Mike
Mike
