jhdeval
I know this has been beat to death but i am just curious im about 8 degrees before tdc. The engine sounds good and runs like a top. Is that a reasonable degree of timing?
805 moparkid yes dead stock. The only thing i did was rebuild the head
It was up to about 20 degrees and it drove but not great at idle the engine would vibrate.
yea, my 66 does the same thing when you over advance the timing. Its because the engine is running rougher at idle, and the motor mounts are worn completely out. The lower and rougher idle makes the car shake, lol. Thats on mine anyhow.... Mounts are completely cracked up.
