Hey, Here is a link to the you tube video of the 11.00 run. Also a rundown of the current parts list. Just a happy little Valiant. Later
Ryan
http://www.youtube.com/watch?v=OwEcKWTEuCo
Standard bore 225 (swather) stock deck ht, stock crank, bearings & oil pump (45 psi), all 1972 vintage.
TRW Forged w/ speed pro moly rings
Comp cams pushrods
Dual springs w/ stainless 1.70 in / 1.44 ex
1970 head - uncut surface (just cleaned), Bowl port, no gasket match
Erson turbo cam & lifters .465 lift
Stock computer controlled Dist (no weights) - 21* total
Orange box w/ MSD blaster coil and wires
Custom Header w/ 3" turbo inlet and 3" outlet
Garret T70 Turbo w/ stage 5 wheel - .58 hot - 70 cold - P trim
Greedy BOV - China wastegate
Extreme V carb bonnet
BG Demon BT 575cfm
Devils own Meth w/ 100% meth - 14gph jet
Ebay intercooler and plumbing
GER 4000 stall
727 trans - Manual Valve body
Stock rebuilt susp w/ drums on all 4 (4" bolt pattern also)
8 3/4 2.94 gears, spool
Aeromotive A1000 pump and boost reg w/ return and cell
Amsoil 20w50 racing oil - Amsoil Super Shift (trans) - Amsoil 75w90 Severe Gear in rear
26x8.5x14 ET Drags
Just under 3000# w/ me
