Are you working you port without taking your entrance plate off.
Depends on the situation. In this case it was left on since I was working only the straight wall and deep in the port.Are you working you port without taking your entrance plate off.
My next step would be a quick and easy one…….
Clay in the sharp corner in the chamber that was left by the edge of the 15* cutter……..so it’s like the cut was made with a blade that had a radius on the OD.
It probably won’t do anything at this point, but it would be nice to have the chamber form more “correct” moving forward.
My take on where it’s at right now is……… the SSR is still in control at the higher lifts.
Well, you’re in charge……. What’s the next move?
Bottom of the bulge now 0.124", top is 0.128". That makes material removed in 1st step around 0.020"-0.030".Interesting. Something I’ve never done or never will do. Did you sonic check it yet.
Want the colors gone for the pictures?I would sure like to see a nice close up of the chamber around the intake valve. Don’t be cheap with the pictures. I can’t imagine a ridge in the chamber that is so bad it couldn’t be addressed with a 3/8 sanding roll. I really don’t like his choice of tooling
So make another cut on the head bolt pinch?Well if you have .125 leave .060 for now.
Here's the pictures. There are no ridges in the chamber, other than that created by the plunge cut. A little chatter, but no ridges.I would sure like to see a nice close up of the chamber around the intake valve. Don’t be cheap with the pictures. I can’t imagine a ridge in the chamber that is so bad it couldn’t be addressed with a 3/8 sanding roll. I really don’t like his choice of tooling
It was the one in the picture. It was square. There is a 105 degree sharp inside corner formed by the plunge.Looks like the 15* bit you used for the top cut has a radius on it?
I guess I thought it was the one you posted a pic of previously that was squared off.
Sort of the same thing happens when the PRP is opened without changing the SS. It exposes the other problems. The factory sizes the PRP the way they do for a reason.My take on “bigger” valves being put into heads that are less than optimum in the SSR area is that it usually makes the shortcomings of the as cast SSR form more pronounced.
Exactly...the belly of the ST + IMO the valve job and transition into the chamber + lack of area around the valve is causing problems the bolt bulge and pinch won't cure.My take on “bigger” valves being put into heads that are less than optimum in the SSR area is that it usually makes the shortcomings of the as cast SSR form more pronounced.
The pinch should really not hurt a port like this...even if it's a bit large. I really think it's the valve job/chamber hurting things. Still fun to see what the changes you make do. What's really fun is when you unlock or find what the port really likes. Then it's like magic and makes you feel all warm and fuzzy!Sort of the same thing happens when the PRP is opened without changing the SS. It exposes the other problems. The factory sizes the PRP the way they do for a reason.
I watched a Youtube video with Curtis Boggs and Jeff Hammond. Curtis talked a bit about monitoring pressure differentials (pressure drops) in different parts of the port to help really figure out what's going on with these low port heads. I think that would apply here.
That is a very subtle undercut. I went way to far with mine (different port than the one in this post). Thanks. Burr finish in the chamber as well. Beautiful work.
