Small block 90 degree oil adapter
Anyone able to tell me why there is both cast iron and aluminum ones.
Aluminum ones were used on the 80's FMJ bodies that had 3 cats total on the exhaust. One of the two pre cats that occupied a lot of space near the oil filter area.
As far as I know all the 340 factory pieces were cast iron, but I can't say for certain.
Direct Connection offered an aluminum 90* adapter and I believe Mopar Performance did also. I have an aluminum adapter on my 416 vs the cast one on my 408.
There is 5 different versions, a steel true 90 used on the early 273’s, a steel one on the 340’s that angled different than the 273 ones, a stock cheap thin aluminum one that was used on some 1980’s models, and 2 slightly different Direct Connection ones that look like the 340 ones, except made of aluminum.
