moparfan68
heres a used small block mopar cam its a crane energizer 272 h 10. im asking $60.00 plus shipping from fieldale va. heres the specs on it.
Manufacturer's Part Number:15005
Product Line:Crane Hydraulic Flat Tappet Camshafts
Summit Racing Part Number:CRN-15005
UPC:021174019483
Cam Style:Hydraulic flat tappet
Basic Operating RPM Range:1,800-5,200
Intake Duration at 050 inch Lift:216
Exhaust Duration at 050 inch Lift:216
Duration at 050 inch Lift:216 int./216 exh.
Advertised Intake Duration:272
Advertised Exhaust Duration:272
Advertised Duration:272 int./272 exh.
Intake Valve Lift with Factory Rocker Arm Ratio:0.454 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio:0.454 in.
Valve Lift with Factory Rocker Arm Ratio:0.454 int./0.454 exh.
Lobe Separation (degrees):110
Grind Number:272 H10
UPC:021174019483
