Will try and report back.did you try with out vacuum advance? Maybe it´s too slow coming back under full throttle....
Michael
Michael
Yes the chambers were just cleaned no real prep work other then a good valve job I'll get back to ya on the cranking pressure. ThanksUnless you have over 170 cranking psi on un prep'd chambers ...Primary jetting is lean=surge at cruise.
The old mp .490 lift solid would be great for your combo, with 1.6 even better.
Rumble fish 360.Jeff, thanks for accepting my sense if humor today.
Seriously, more cam would be my "Up the anti" choice.
A surge is lean & the distributor needs a tuning. Not coming in so fast.
RRR, is there a smiley that is giving out razzbeeries by chance?
Insert here ---->
LMAO
YR, you should have left a link to your post, "Help me choose a cam!"
And "I'm all over like a drunk out of a weekend lock up that just ran into the liquor store with a hundred bucks!"
(Funny thing is, my hot rod guzzled gas like that on a regular bassis! AKA W.O.T.! )
FWIW, I came up with the same numbers as AJ for DCR etc., ASSUMING a .039" thick head gasket. If you have the head gasket info, that would be helpful; with a .028" thick head gasket, DCR bumps up to around 8.2. Should be doable, but moving to 93 octane would help (if you are not using it already).
FYI, humidity will tend to LOWER the tendency to detonate. Some research work in the 80's concluded that going to your humidity levels approximated the same effect as 3 to 4 points increase in octane. So you are REALLY doing something special to get into detonation LOL
Post #1 is full of info
but the most important info is missing. How much cylinder pressure is that engine running and at what altitude is it operating?
KB107s are flat-tops and in a 360 sit down in the hole. X-heads are open chamber items. The 262 has a very early ICA. But unless you have done a lot of machining, the engine should not be detonating. Well yeah your timing is all in a little early, but there is something you haven't told us,namely the cylinder pressure..
A little detective work,; with no machining, this is a 9.5 engine. the 262,in at 106 makes an ICA of 59*. This conspires to make a Dcr of 7.9 and cylinder pressure of 158 at sealevel;just about perfect,for iron heads.And should not require 93.
Soooooooooo, what's your pressure.
Three things lead to detonation; too much heat, and too much heat, and too much heat; for the fuel.The heat can come from excessive pressure,too-early timing, a hot-running cooling system,hot-air intake,hot spots in the chambers,restrictive exhaust, or lean AFRs.
Did I miss anything?
Oh yeah, too high a load.As in secondaries coming in too soon.
-If it detonates after 4000, you can probably rule out your timing. That combo should run full-timing ok at 180*engine temp.If you have a scoop, you can rule out hot-air. If you have headers and duals exhaust looks covered. That leaves just; pressure,hot-spots and AFR.
-But if it detonates right from the get-go, Perhaps the secondaries are coming in too early,or the exhaust is not getting out,or as you have already surmised, the timing is all-in too early.
-If it detonates between say 3000 and 4000, then cutting back the timing should help.But you tried that and even at 30* it is still detonating.
Soooooo, what's the pressure?
-If the pressure is below 160psi,and timing is under 36*,and it still detonates after 4000,then you have three choices,I think; Hot spots in the chambers,Lean AFRs, or hot inducted air.
It's all about too-much heat,or too much load.
Ok here's a wild card; the heat could be from something in the chamber that should not be in there,lol. Like exhaust,engine oil, something in the gas,or not in the gas that should be in, or a gasket overhanging the top of the bore,or plain old carbon. I would clean out the chambers and start over.
-If the pressure is over 160, you are gonna have to be sharp on the tune.
I like this combo;it should make a ton of torque, and be a pleasure to cruise around in. I also see lots of tire-smoke
Sir I've had them for about 20 yrs and have been fanatical about keeping them in position. Especially when setting mixture on rear carb. What a pain. Thinking of changing base plate in rear to one of the proform wt angled mix screws. Also may swap jet plate.BTW, you mention six pack. Are all the carbs the right ones in the right positions?
Hmmm. That does not compute out with the info given for the build. (Assuming an XE-260 cam...) Is this a Magnum block? Or were the heads shaved a fair amount? Or is the cam advanced by a whole tooth?AJ/Forms.
Cylinder pressure is 182 psi. Cold.
Higher than I remembered
Thanks.
I am coming up in the range of 155 psi. You would need an SCR of about 10.5:1 for that 182 psi pressure with a 260 range cam. Do you have access to another gauge?
BTW, the cam number given looks to be for a Chevy small block. Can you re-confirm that cam part number?
They were down in the hole but just slightly. Interesting.BTW, for 10.5 SCR, the head chambers would have to be around 65 cc's (NHRA minimums) with the .028" head gasket, or around 60-61 cc's with a .048" head gasket.
Or maybe the block was decked down a fair amount. Were the KB107's truly flush to the deck? With a stock deck they would be about .012" in the hole.
Well, .012" inch below deck is right for these KB107 pistons and the stock deck height and stock rods, and that seems like 'slightly' IMHO.They were down in the hole but just slightly. Interesting.
182 is about perfect for aluminum heads. For iron, down around 165 will work.
I think you're gonna need to lose some cylinder pressure.
So perhaps the heads have been milled a bunch. Do you recall if the 'open' part of the chamber on the heads was very shallow? The stock area is around .090" deep; if the heads were milled about .060", then the chamber size would be down in the low 60 cc range.
And using nail head valves (straight across on the main surface in the chamber) would lose another few cc's. And then there is the head gaskets.....lotsa variables.
I think I would still try one more compression gauge....
Roger on the gauges; I suspect you are spot on. It's just to avoid any teardowns if possible.
All the above ideas are on the table if the cranking pressure is still up there in the 180ish range. In order of effort and cost:
1. Thick head gasket: Think Cometic. If it were the case that you had 65 cc chambers with a .028" thick head gasket, you would have to go to around .065" or .070" thick to get the SCR to 9.5 or a bit less, and the DCR to 7.9-8.0. If the chambers are smaller, then the gasket needs to be thicker. I have no idea just how thick you can go, and if there is any risk in blowouts, but Cometic makes them well over .100" thick. You can always put in ARP heads studs and clamp the heads down harder. (Keep an eye on the rocker oiling path in the head bolt hole with ARP studs.)
2. Cam change for a later intake valve closing from some combination of :
- Wider duration
- Wider LSA
- Less advanced cam timing
This is gonna change the engines personality more than the compression drop, so if you picked the cam for a particular purpose, then perhaps this is the last thing to consider.
3. AL heads: Maybe look at the Edelbrock 63 cc ones (closed chamber) and Cometic head gaskets around .055", or the 65 cc 'open chamber' versions, with the 8553PT head gaskets. Either will put your SCR in the 10.0ish range, and DCR in the 8.4-8.5 range.
The AL heads are the costliest solution but also keep the SCR up higher to help maintain the crisp low RPM torque you have now. And the breathing will be great and will help performance across the board. Do you have the stock rockers right now?
