[SOLD] Small Block Comp Cams Timing Chain - New
Rocket
CT
I have a new Comp Cams double roller timing chain for small block LA engines. Comp part number is 3103. Description from Summit Racing is as follows.
"COMP Cams Hi-Tech Roller Race timing sets are designed for extreme racing applications. They feature double-row chains with oversized rollers for extra strength and reliability, plus crank sprockets with three keyways. These three choices allow you to set cam timing at normal, 4 degrees advanced, or 4 degrees retarded. Hi-Tech Roller Race sets are dynamically balanced for smoother, more accurate operation, with less fluctuation."
Price on Summit is $69. I will sell this new set for $60 shipped in the lower 48 states. PM me with any questions.
