[SOLD] Small Block Crane Ductile Iron Rockers, Grooved Shafts & Spacers- New
Rocket
CT
I have a new small block Crane ductile iron 1.5 ratio rocker arm package. Comes with the rocker arms, adjusters, rocker arm spacers, a set of stock hold down hardware (stock factory hold downs and bolts are included but not pictured) and a set of hard chromed and banana grooved shafts. All parts are new except the hold down hardware. The shafts are heavy duty and thicker than the stock shafts and many replacement aftermarket shafts. As you can see in the third picture, the crane iron rockers have a groove that circulates pressurized oil around the rocker arm to the holes that lubricate the push rod cup and valve tips.
Here is some information on the rocker arms from summit racing.
Brand: Crane Cams
Manufacturer's Part Number: 69770-16
Part Type: Rocker Arms
Product Line: Crane Steel and Ductile Iron Shaft Mount Rocker Arms
Rocker Arm Mounting Style: Shaft
Self-Aligning: No
Rocker Arm Ratio: 1.5
Maximum Spring Diameter (in): 1.565 in.
Rocker Arm Style: Non-roller
Shaft Diameter (in): 0.872 in.
Rocker Arm Material: Ductile iron
Crane uses a high-quality steel alloy or ductile iron that's heat-treated for strength and wear resistance.
I am selling this package for $460 shipped in the lower 48 states.
PM me with questions.
