junkyardhero
another set of the tasty bits from under the timing cover: used OEM pump eccentric & bolt/washer, thrust plate, bolts, chain drip tab, and fuel pump bolts.
all parts are factory original, no offshore junk, no hardware store bs. cleaned and inspected, ready to go.
**this set does not include the oil slinger**
this eccentric shows a more pronounced visual wear pattern, but you can't hardly catch a nail on it. the blemish on the thrust plate is not corrosion, the plate is perfectly smooth, that's just how the metal cleaned up.
$65 + shipping
$65 + shipping
