svitaks
Member
Ok i need to get things straight. My buddy has a 318 out of a 84 truck would putting 340 2.02 heads on this stock bottom end motor kill the compression. I thought i read that all small block heads had a 70cc chamber but different valves and runner sizes. Also what years did they make the closed chamber heads? We were curious if it would be worth it to switch back to the stock heads. By the way the pistons are stock.
Also what do you guys w/ small blocks run for total advance w/ out the vacume advance?
Thanks to all who can help
