Confusedcuda
Hello, If you switch to a hyd. cam and hydraulic roller lifters, do you need to switch the rocker arms? Thanks
I don't believe you can use stamped steel.
Why?
Struggling to see why rockers matter with roller lifters, assuming you have to correct length pushrods.
I know what you meant.The rocker will break under the load required to control the heavy hydraulic roller lifter. Spring pressures are much higher than a hydraulic flat tappet. Also depending on the lifter you will need to bush the lifter bores or the lifter will leak and the motor will have low oil pressure.
You're right, the heavy valve springs that are required for Hyd rollers will break stamped rocker arms.The rocker will break under the load required to control the heavy hydraulic roller lifter. Spring pressures are much higher than a hydraulic flat tappet. Also depending on the lifter you will need to bush the lifter bores or the lifter will leak and the motor will have low oil pressure.
I mean.... 318's and 360's cam with roller cam/lifters and used the stock stamped steel rockers/shafts. Only need to switch is for strength, depending on how much spring pressure/lift you are using. I have over .500 lift on a 5.9 magnum and using the Hughes spring kit with the stock rockers, no issues yetHello, If you switch to a hyd. cam and hydraulic roller lifters, do you need to switch the rocker arms? Thanks
