moparmarkk
hi,just got a macho dodge pick-up,the intake casting number is 2846707.it is a four barrel,but from what?i can not find this number anywhere,any help out there?thanks,mark
hi and thanks for the replys.manifold has big rake for carb base and that is what thru me off.it might look good with a carb on it.it did not come with one.thanks once more,markFrom what I found, this appears to be a cast iron intake manifold for
Chrysler marine engines
INTAKE MANIFOLDS
LM318, M340 & M360
2846347 and 2846707
Used 1968 to 1974 - Raw Water Cooled Engines with Two Impeller Raw Water Pump & Carter 4 BBL Carburetor.
