I have a nice used Comp Cams small block cam and lifter kit for sale. This kit has only about 1000 street miles on it and about 20 passes down the track. It came out of a 340-stroker motor and was replaced by something bigger. The CC number is 20-224-4. Here is a link to the specs.
http://www.summitracing.com/parts/CCA-20-224-4/
It has a .488/.491 lift with a duration of 230 int./236 exh. at .050 lift. The rpm range is from 1,800 to 6,000 rpm. The lifters are in a box marked so that they go back onto the original cam lobes. Id like to get $100 plus the shipping for the kit.
Ken
Edison, NJ
Ken
Edison, NJ
