I usually use Ferrea valves on my small block Mopar Edelbrock style heads and will be buying a few sets. (2.05 and 2.08 plus .100 Chevy). What manufacture are you guys using?
How was it running in the two or three passes before that happened? Any warning signs at all?I’ve been running the stock Edelbrock exhaust valves for years with zero issues probably because of their weight. But we did have a 1/4 inch piece of a stock Edelbrock intake valve break off on number 3 and lodge in a piston on number 6.
I use Ferrea in a set of heavily ported j heads. I also wanted to use these for a set of cnc'd speedmasters, but the delivery times are very long. That's why switched to Manley and also takes a long time because they put the wrong damn valves in the box!
Normally no problem. But almost everything i need is in backorder. I have a contact in the US who bundles all my orders into one package. He can also adjust the total value to reduce tax.Man that would stink especially where you live.
Question, do those 2.05's along with 1.600 exhaust clear the cylinder bores and what about the distance between the valves? I'm wanting to learn more about the performance world of the sbm's.I usually use Ferrea valves on my small block Mopar Edelbrock style heads and will be buying a few sets. (2.05 and 2.08 plus .100 Chevy). What manufacture are you guys using?
You running 1.600" exhaust valve's? I remember reading that there's suppose to be a minimum clearance of 0.03" between the valves, is this true?The head with 2.05’s is on my flowbench right now on a 4.015 bore adapter. [email protected] (he’s running a 575 lift cam). I run 2.08 valves in mine on a 4.030
Bore.
Yes 1.60 exhaust valves.You running 1.600" exhaust valve's? I remember reading that there's suppose to be a minimum clearance of 0.03" between the valves, is this true?
Sounds like a runner for sureYes 1.60 exhaust valves.
What rpm range will it run in with those size valves, camI think he will be happy
With a 2.05 valve size. Using a 2.08 like I have only bumps you up to 315-318 cfm with a 195 cc intake runner. They become very touchy in that area and very dependent on short side size and shape.
I've heard that to,but I don't know for sureI’m not sure where he will be shift at but my 408 went 5.98 which would be around a 9.30 shifting at 6700 rpm. I may step it up some next year just for a new best in some good weather but it’s just a bracket build so why beat on it. I keep hearing these stock blocks can’t take much.
