[FOR SALE] Small Block Mopar Performance Purple Camshaft
DavidLee
Torrance, CA
used with lifters. The lifters are in boxes with the lobs they are matched to on box,
Here are the specs for the cam
Basic Operating RPM Range:2,800-6,200
Intake Duration at 050 inch Lift:248
Exhaust Duration at 050 inch Lift:248
Duration at 050 inch Lift:248 int./248 exh.
Advertised Intake Duration:292
Advertised Exhaust Duration:292
Advertised Duration:292 int./292 exh.
Intake Valve Lift with Factory Rocker Arm Ratio:0.508 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio:0.508 in.
Valve Lift with Factory Rocker Arm Ratio:0.508 int./0.508 exh.
Lobe Separation (degrees):108
Asking 130 plus the ride
MP 292/.509 camshaft from the looks of it. Numbers on back dont mean squat as it was a contracted grind.
