[SOLD] small block mopar solid roller cam
dartrunner
Active Member
pennsylvania
Rating - 0%
0   0   0
New small block mopar solid comp cams billet roller cam. comp cams grind Z0438 specs are as follows: This cam is for use with standard 59 degree small blocks
Serial # Z 0438 Spec Card# 034911
Part # 20-000-5 CAMSHAFT, CRS CHRY 273-360 FT
Core C20-4 CAMSHAFT BLANK, CRS CHRY 273-360 FT
Grind # CRS 7130 /7130 S 110.0
DURATION @ .050 INTAKE 239 ROCKER ARM RATIO
VALVE ADJ INTAKE .020 DURATION @ .050 EXHAUST 239 INTAKE 1.50
VALVE ADJ EXHAUST .020 LOBE LIFT INTAKE .3560 EXHAUST 1.50
VALVE LIFT INTAKE .534 LOBE LIFT EXHAUST .3560
VALVE LIFT EXHAUST .534 LOBE SEPARATION 110.0
DURATION .020 INTAKE C/L 106.0
TAPPET LIFT INTAKE 268 CAM ADVANCE 0
TAPPET LIFT EXHAUST 268 HYDRAULIC
VALVE TIMING .050 OVERHEAD CAM N
VALVE OPEN INTAKE 13 JOURNAL DIAMETER STD 1.951
VALVE OPEN EXHAUST 53 RECOMMENDED VALVE SPRINGS
VALVE CLOSED INTAKE 45 DEPARTMENT R
VALVE CLOSED EXHAUST 5 SPC INSTR FOR CUSTOMER
$250+shipping I do have a used set of used comp cams valve springs I will throw in with the deal. They measured 250 psi @ 1.900 installed height 1.550 diameter. Buyer pays shipping or can pick up locally near scranton pa. Many new and used small block race parts for sale.
