[FOR SALE] Small block Mopar stroker pistons
pittsburghracer
Legandary Member
Legendary Member
Freeport, PA.
Small block Mopar Wiseco stroker pistons with rings
$575
Freeport, PA (16229)
Brand new set of .060 over (360) Wiseco stroker pistons (4 inch crank)
comp HT. 1.460
546-547 grams
.984 piston pin
525.00 plus shipping with .043 rings included (rings cost over 250.00)
Located 35 miles NE of Pittsburgh, PA. 16229
These also work in a 340 with a 4 inch crank but I'm not sure what rod size is required.
message me.
All small block engines have the same rod size/length. However, on a customized stroker, this could vary depending on the blocks deck height and where you would want the piston to reside when the build is finalized.
With a 1.46 comp. height, and 4 inch stroke, stock length rods will work with a stock block.
