earthmover
in the tire smoke
this parts are used but in good cond.
.i have two sets of heads 1 set is 240/140 @500 with springs for the 306 mag cam port work.$500.00
2.next set of heads are about the same as for a port work with comp 995 springs this heads are the heads that took the car to 7.44 the other heads would have but had other problems with the combo when it was put together..$500.00
3. comp cam 292 501 hyd. cam new never been in a motor $75.00
4.set of heads with mp red springs stock cond. took of my 340 when i got it and never used them so they will need to be worked on..$100.00
5. set of 5.13 gears about 20 i think pass on them $75.00 for 489case
6. 8" alum. rims was going on the new prooject but plan to get 10 instead
$200.00
7. stock type radi had it in my 74 cuda been settting for bout 8yrs $60.00
8.c-body radi i had in my 70 duster til i went alum. it has 1 mount that need to be put back on the side but kept the 340 with 11.1 comp cool at 180 with mp fan had shroud on as well $50.00
9.mp cam 324 with 620 lift soild cam was in x block when i got it $50.00
10. 6cyl trans pulled good 50.00
11. 7 1/4 rearend good shape $100.00
12. torker340 intake port matched to the #1 heads $125.00
13. have 4 rally wheels have to check the bolt patt. think its small came off 72 dart $150.00
price is with out shipping im located in north carolina
pm me here or call cell 252-904-94478)
thanks for the free ad abodies.
$200.00
