[SOLD] Small Block Rocker Arm Shafts for Mechanical Rockers - New
Rocket
CT
I have a new set of small block Mopar rocker arm shafts for LA type cylinder heads. These shafts are made here in the U.S.. The shafts are made from thick induction hardened steel. They feature banana groves and oiling holes that are positioned for the loading of mechanical rocker arms (a little forward of straight down towards the valve spring). These shafts have screw in end plugs for inspection and easy cleaning. These are drilled on center for the hold down bolts and are for use with stock small block Mopar heads (273, 318, 340 & 360) or aftermarket cylinder heads including Edelbrock RPM, Indy LAX or other similar shaft mounted cylinder heads where mechanical rocker arms are being used. These are not intended for W2 or W5 heads.
These shafts will provide the proper oiling to high load areas for adjustable iron and aluminum rocker arms to minimize wear and maximize performance and parts life. They are far thicker and stiffer than stock or may aftermarket shafts to minimize flex with stiffer aftermarket valve springs.
Price is $180 for the pair shipped within the lower 48 states. I can ship internationally for the additional shipping cost if any.
PM me with any questions.
I bought a set for my 408 build. They polished up to a mirror shine with little effort. Not trying to violate rules, just adding information.
Bump.
1Badcolt I sent you a pm in response to your question.
I'll post a photo of these shafts sitting on my new Trick Flow 190's. Machine art, IMO.
Looking forward to the pictures.
More sets available.
