Uh, what else would use the Magnum 5.2/ 5.8 engine?
A Van too i guess.
http://www.partzfinder.com/category_s/56.htm
http://www.partzfinder.com/Mopar_SB_BB_High_Torque_Mini_Starter_p/pfp-17466.htm
Mopar SB/BB: High Torque Mini Starter
Our Price: $99.00
Stock Status: In Stock
Availability: Usually Ships in 24 Hours
Product Code: PFP-17466 Qty:
This High Torque, Off-set Gear Reduction Mini Starter offers a significant weight savings over an older stock starter; this starter only weighs 8.4 lbs. It fits Mopar Slant 6, SB & BB engines (170-440). It provides 50% more torque than stock starters and weighs less than 8.5 pounds.
Specifications:
Features
Nippondenso Off-Set Gear Reduction (OSGR) starter
1.4 kW, 12 Volt, CW, 10-Tooth Pinion
Lightweight
Compact
Gear reduction
Draws less than half the amps are early starters
