small bolt pattern to big bolt pattern
George Lawicki
Cleveland OH
My 74 Dart swinger has factory disc brakes with the small bolt pattern if I were to change it to the large bolt pattern what is the process its not just getting new hubs ?
Unless for some odd crazy reason, it has the earlier Kelsey Hayes small bolt pattern discs with the 4 piston calipers.
We need some pictures . . .
Not from the factory at least, last year for K/H was '72... but that doesn't mean someone couldn't have swapped them on to a drum car... pics will tell the story!
You don’t have small bolt pattern Kelsey Hayes 4 piston caliper brakes on your car. You already have Large bolt pattern single piston caliper brakes. I looked at your previous posts to determine this. My 74 Dart 2nd set pics
Now that I’ve saved you a thousand or two, dollars You can send me a 24 pack of Widmer Bro’s Hefeweizen. Hefe - Widmer Brothers :)
