Small bolt pattern wheel spacers
340rag
Member
Looking for a pair of wheel spacers for my Duster 4 lug pattern not 4.5 and 1/8 or so thickness any ideas?? Appreciate!
If you're just using 1/8" thick spacers you should be able to use spacers for a 5x100 mm pattern. I wouldn't use rims with that pattern, but the spacers should work just fine as the lug holes will be oversized enough to make up for the minor difference in the pattern.
