Small bore flow numbers.
273
Ontario
Anyone have flow data with any mopar head with a 273 bore size pipe?
If you do can you give the specs of the head and the inchs of water it was tested at. Please & Thanks
The two heads I'm mainly interested are RHS and EQ any info would be helpful.
No one with a flow bench can check or has checked the effect small bore on 340/360 heads flow numbers?
