homeboysduster
i've found a junk yard with a few early 8 3/4 rears with the 4 in bolt pat. i'm wondering if an aftermarket axel is out there that would give me thw 4 1/2 bolt pattern with only a drum swap?
guys i was wondering if you could tell me if there is a way to ID a 8 3/4 rears gear and if its a posi with out taking the thing apart? junk yard shopping can be tricky!!!! if you know what i mean!!!
the yard told me he has every thing from a one wheel wonder to a 4:10 pos. from $100 to $800. this yard tas been around sense the 50's and i've saw a few of the rears. i've priced rears on the web they range from $2000 to$4500 BIG BUCKS for a little guy like me!!!!!:-D
i didn't say the "rears" were 8 3/4 these were ford 9's and dana 60's most wouldn't even really try to talk to me about building me a 8 3/4. said thay a x brand would be better and the 8 3/4 was a weak rear for a 500 HP motor!!!!for an a body 8 3/4 ???? where do i find morons like that , I've got one I'm selling to a friend I'll sell for 2k :toothy10:
I tried a couple of machine shops locally. One would use a CNC's and quoted me $125 on for the axles and drums....until he saw what meat would be left over on the axles. Even using screw in studs he wouldn't touch it. Another place would do it, on manual machines and wanted around $400. I ended up ordering sbp steel wheels for around $300. Last night while looking on Summit, I came upon this for 8 3/4 rear ends. Disc brake conversion and lbp for $450. Wish I had seen this (or if they even had this) a couple of years ago.
http://store.summitracing.com/partd...908110+4294908090+4294925084+115&autoview=sku
Just looked at it again, I wonder if the axles need to be lbp, but it they are specifically for 65 to 72 A bodies
that summit link for the disc brake conversion listed above. Will that work for my 75 scamp? It only lists to a 72 so im not aware if they changed anything or not.
Thanks,
Joe
