small to big conversion ujoint !!
7dart0
peabody,ma
where can you get one of these conversion ujoints? i have a small yoke on the driveshaft and a big yolk on the pinion.
thanks tom
Here's some numbers for ya.
Or Napa 347 is how I ordered mine.
347 is Precision. "They used to be" good joints. Someone on the www insists they are now chineseoated, the last couple / three I bought were U.S. or a big lie, I don't know which.
All I can say is it looked good, but who knows what the metal is like anymore.
Probably has rice hulls in it. :D
I don't know why we put up with this serious decline in quality of damn near everything from auto parts to technology we use.
Just today our damn Vizeo TV said it was connected to the wireless with a good signal, but attempting to use any of the "DUMB" Smart functions that require internet says you have a network issue and won't work.
Everything else in the house that uses internet was fine, and I finally had to run a cable from the router into the living room and also do a factory reset on the TV so the Wife could watch Netflix tonight.
Screw the wireless as I'll just run a line to it under the house.
The Mayor has a sticker on the front of his computer that say's "Technology, a blight on the face of all humanity"
I have one, but there is no part number on it. I believe it was for a '63 Pontiac, or some weird thing but was an exact fit
Whats your wireless protocol on your router? Vizio needs WPA2-PSK, wont work on WEP or WPA-PSK. Get into your router (192.168.1.1 maybe) and change to WPA2-PSK, then try again.
If connected to the router as an access point that would be what it would use, but not as a straight wireless with a passcode.
It got progressively worse over the last year or so and had worked just fine before that started.
Here's one for you.
I bought a brand new Motorola fast *** modem/router recommended by our cable company to take advantage of the highest available speed and throughput only to get it home and find out that it was slow as hell and when I told them what was happening they told me to turn off the WPS function in it because for some reason it interfered with the speed of the modem/router.
It was true, and when I turned WPS off in the modem/router the speeds came up where they should be.
What the hell I ask you, what the hell? :D
I do computer service work for a living and the amount of things that don't work at all or just barely do in our devices these days along with the takeover of commercialism on all of them is pretty annoying.
thanks tom
any auto part stores -- small to big u -joint --- Spicer 5-527X --- Precision (Moog) 347 --- TRW (Federal- Mogul) 20226
