Smaller wiper motor
Swanny253
Member
Tacoma wa
Is there anything out there to swap my stock 72 wiper motor with it hits my distributor cap slightly on my small block msd distributor
Three speed wiper motor. But you'll need to change switch and other stuff.
I was mocking of an 8-stack efi setup for future use and ran into a clearance issue. I sent my motor assembly to Newport Wiper and got back a 2 speed sideways mount unit with a correct mount plate (and the original motor). No more resistor as the speed is reduced internally. Works great, a little pricey, but if I had to add up the 3sp motor, crank arm, linkage, switch and wiring changes (time being free) still close for new parts at around $500.
