One of my co workers has one and it makes amazing food. Its a little more traditional so you have to kind of baby sit it adding chips when needed, about every 45 minutes. I have a pitboss vertical and another co worker has a traeger. All have there pros and cons. Pellet grills can be set it and forget it, smoking something is usually several hour or more, so I like that I can load it up and leave. I have a wifi controller so I can monitor it from my phone. Pellet grills require regular maintenance to keep them working properly and not as much smoke flavor as a traditional smoker but you can get different favored pellets that give better flavor.Ok guy/gals, I think this is the one I will get. It’s a Masterbuilt #277089. It’s $299.99 Canadian plus taxes. It is digital. It is insulated. It is electric. 4.4 stars out of 5 stars. Anybody have 1? Sold by Cabella’s. Thanks for all the opinions. Kim
I do also add wood chips. Not only for its added effects. But to get the charcoal going more evenly.Charcoal is consistent heat . Most of the smokey flavor is derived from the first 20 minutes cooking. When I can get it, I throw a few chunks of Red Oak bark in just before the lid is closed.
I'd say look for a used weber smokey mountain. You can find deals because they are a little harder to use vs the pellet smoker (people by them and they just sit). Won't have much invested if you decide you don't want to smoke food. I'd get at least the 18.5". I like my 22.5 because I can fit a large brisket and multiple ribs without having to trim.
Also it is very easy to smoke food on a regular weber 22.5 kettle.
8 Easy Options for Smoking on a Weber Kettle - Weber Kettle Club
