Snap on something?
Shop, Garage and Tools
  1. tenfive0
    tenfive0 Member
    22
    16
    May 4, 2020
    Lehigh Valley, PA
    Local Time:
    12:20 PM
    Anyone familiar with this or ever used one. I remember years ago when I was a gas jockey at an Exxon station the shop mechanics used one. But I forgot more then I can remember.
    It came to me for free. I'd like to get an idea what it does and how to use it. It is supposably in working condition but there are no instructions. It looks cool enough with lot of knobs to turn to keep my busy and entertained for awhile. If I can't figure out what is does or how to use it I'll just add it to the collection of shop novelties and look at it wondering the possibilities. Maybe I'll use it as a boat anchor. 20200530_134013.jpg 20200530_133950.jpg
  2. Demonracer
    Demonracer 71 Demon 00 Ram 16 Chrysler 300S 05 Caravan FABO Gold Member
    3,303
    1289
    Jan 31, 2010
    Cleveland, Texas
    Local Time:
    11:20 AM
    Contact toolmanmike on this site, I'll bet he can help you.
    • Thanks! Thanks! x 1
    • petty437
      petty437 FABO Gold Member FABO Gold Member
      186
      95
      Feb 5, 2014
      Kent, Ohio
      Local Time:
      12:20 PM
      • missing linc
        missing linc Loose nut behind the wheel FABO Gold Member
        1,438
        2077
        Feb 17, 2019
        Southern Alberta Canada
        Local Time:
        10:20 AM
        Looks like an engine analyzer from the 70s or early 80s.
        • Agree Agree x 1
        • RustyRatRod
          RustyRatRod Bla de blizhibliz de blatde blizi bla bla FABO Gold Member
          60,809
          32468
          Jun 7, 2010
          Georgia
          Local Time:
          12:20 PM
          Tuneup oscilloscope.
          • Agree Agree x 5
          • Like Like x 1
          • toolmanmike
            toolmanmike FABO MODERATOR Staff Member FABO Gold Member
            49,489
            34278
            Jan 18, 2006
            Iowa
            Local Time:
            11:20 AM
            @halifaxhops deals in those.
          • Syleng1
            Syleng1 Karma is real and Life is short... FABO Gold Member
            1,525
            1120
            Jul 5, 2005
            North Franklin, CT
            Local Time:
            12:20 PM
            What RRR said. We used those long before computers. You could analyze each cylinder, kill a individual cylinder. Rev the engine and watch for spark drop, misses and even how much voltage was needed to see if a plug or coil was dropping out or shorting internally. The one I learned on was about 10 times bigger and hung from the ceiling on a track so every bay could use it. Tons of harness when to it.
            • Agree Agree x 2
            • Joey4speed
              Joey4speed FABO Gold Member FABO Gold Member
              678
              466
              Jul 17, 2018
              Jersey
              Local Time:
              12:20 PM
              Yep. You could easily see a spike in one or more ignition wires.
              I was trained breifly but that was it.
              Was expensive in the day.
            • pishta
              pishta I know I'm right....
              17,308
              6919
              Oct 13, 2004
              Tustin, CA
              Local Time:
              9:20 AM
              I think it shows an "EKG" of your ignition system, as cylinder pressure can change your spark plug output or something like that (Ask that one ignition maker guy....Taylor? {Jacobs}) Did you get any of the leads?
              • halifaxhops
                halifaxhops It's going to get stupid around here! FABO Gold Member
                59,223
                27496
                Jan 20, 2014
                CENTRURAL, PA
                Local Time:
                12:20 PM
              • tenfive0
                tenfive0 Member
                22
                16
                May 4, 2020
                Lehigh Valley, PA
                Local Time:
                12:20 PM
                The only thing that is attached (hard wired) to the main box is a timing light and large alligator clip battery connectors.
              • halifaxhops
                59,223
                27496
                Jan 20, 2014
                CENTRURAL, PA
                Local Time:
                12:20 PM
                Try to find the leads if you can I bet it works. Ever turn it on?
              • halifaxhops
                59,223
                27496
                Jan 20, 2014
                CENTRURAL, PA
                Local Time:
                12:20 PM
                The leads are like regular battery ones? Get a pic of them and where they come out the back if you can.
              • pishta
                17,308
                6919
                Oct 13, 2004
                Tustin, CA
                Local Time:
                9:20 AM
                if it only measures the ignition pulse and shows each coil strike as a sharp spike (4-6-8 at a time across the board) then possibly that is all it takes. a dead cylinder (low psi) would show a higher spark (less resistance). I think that's how it would measure cylinder health. Could be ass backwards but I know MSD publishes a 'hotter' spark to ignite "higher cylinder pressures" . Same way that ignition box works, ...Jacobs!
              • 67Dart273
                67Dart273 FABO Gold Member FABO Gold Member
                42,943
                10510
                Oct 14, 2010
                Idaho
                Local Time:
                9:20 AM
                When properly working (with proper proprietary connection leads) the scope can measure distributor dwell, show you the condition of the coil and distributor bushings, show you "reserve" coil voltage (voltage above firing voltage) will show the condition of plugs and wires, and notice "cylinder balance." This is an electronic delay gate that pulls down the dwell on one cylinder and kills one cylinder at a time (selectable) You can then measure RPM drop in each cylinder. There are a number of other things that can be done depending on the instrument, I'm not familiar with that exact unit
                The list at upper left says something about alternator. I'd guess at least it can measure charging / system voltage, and possibly amperage. Commonly, these would come with an adapter/ shunt fitting that fit between one battery post and cable (series) and in some cases could measure starter current as well.
                Normally there are clips to the battery, and a clip to coil NEG
                A clip that fits around the dist HV wire, and an adapter that goes into the no1 dist tower Others, depending on model
                I think I can read something says "timing advance" so it should have a timing light with it as well
              • chryslerfat
                chryslerfat Well-Known Member
                12,787
                5780
                Aug 23, 2008
                Monroe,Michigan
                Local Time:
                12:20 PM
              • 67Dart273
                42,943
                10510
                Oct 14, 2010
                Idaho
                Local Time:
                9:20 AM
                ...........Actually you can do a load/ balance test without a scope. You need a good tach, preferably a dwell/ tach that is one with a lower RPM full scale. Pull up all 8 dist. tower boots. Depending on what you have, use a small thin grounding probe, or push very small brads or even paper clips down alongside each wire, so you can go 'round the cap with a grounding lead.
              • missing linc
                1,438
                2077
                Feb 17, 2019
                Local Time:
                10:20 AM
                Used to do that with a test light, go through the wires one by one to find the cylinder that didn't cause a drop in rpm.
              • tenfive0
                tenfive0 Member
                22
                16
                May 4, 2020
                Lehigh Valley, PA
                Local Time:
                12:20 PM
                Front and back. I never figure out how to use it.
                It would help I'm guessing if you had a manual or instruction guide.
