Kenflo Well-Known Member Joined Jun 16, 2010 Messages 226 Reaction score 31 Location Saint Albert Jul 26, 2024 #1 Does the Sniper EFI still “self learn” with the Hyperspark distributor, or is it only a self learn system without timing control?
Dragonsteel Well-Known Member Joined May 12, 2015 Messages 386 Reaction score 546 Location Missouri Jul 26, 2024 #2 It will self learn with or without the Hyperspark distributor, I run mine with a stock ignition.
MadScientistMat Well-Known Member Joined Mar 6, 2008 Messages 645 Reaction score 242 Jul 28, 2024 #3 The self learning for fuel is there regardless of what ignition you have. No EFI system out there is self learning for the optimal ignition curve. Adaptronic tried that a while ago and dropped that feature; it probably didn't work very well.
