superdart
Shade Tree Tinker Gnome.....
I just acquired a new copy of the older Mr. Gasket Dyno2000 software. Mostly I got it just for fun, but can someone tell me if these numbers sound reasonable?
360 bored .030 ( 4.030x3.58 )
9:1 flat top pistons
625 CFM Carter
Edlebrock AirGap dual plane
596 iron heads, mild porting, (1.88/1.60) Procomp roller rockers
E3N herbert cam - .450/.475 lift, 275/285 duration, 112 centerline
Long tube headers, 1 5/8 primary with 3" collector, Edlbrock mufflers, dual 2.5" exhaust with crossover.
Cast crank ground .010 on all bearing surfaces & stock rods
FBO Stage II Ignition 19 degrees at idle, 34 degrees all in about 3200rpms
Sorry, but I don't know head gasket thickness or piston depth in cyl @ TDC.
The dyno software says I peak 350hp @ 5500 rpms and 386ft/lbs @ 4000.
I'm not doubting the software, just curious what others think. I think making almost 1hp/cube isn't bad for as much stock equipment is in the motor.
This isn't the most extensive software, but it's nearly free. I'm not sure how it compares to the true "Desktop Dyno" software.
625 CFM Carter
