MRL Performance
Here are our very own, high quality solid roller lifters for the Small Block Mopars. They have the inboard tie bar, will drop into any block and are the best quality lifter on the market. For the intro price, you simply will not get a better lifter. They have a dedicated oil feed for the roller, so they will last just about forever on the street or the race track.
A deep pushrod seat helps to straighten out the pushrod, giving you more lift and better geometry. This also helps to stabilize the lifter in the bore for less wear on the bore itself. They work without bushing the lifter bore. If you have a bushed lifter bore, we HIGHLY recommend drilling a oil feed hole so the roller can get its pressure fed oil. They also oil thru the pushrods if you want to run that type of rocker system.
There are 2 versions, Pro Sport and Pro Plus.
The Pro Sport is a great lifter for the entry level racer or street engine. It has a .750" roller.
The Pro Plus has all the same great features as the Sport but has a larger .815" roller and a lightened body for more RPM potential. These will be coming soon!!
Pro Sports are in stock and ready to ship today!!
Pricing:
Pro Sport $450
Pro Plus Coming Soon!
Made in the USA
Pricing:
Pro Sport $450
Made in the USA
