Some ported Eddy head pics...
Brian Hafliger
SoCal
#1
more
Flow#'s at 28" and 4.030 bore:
lift intake exhaust
1 70 52
2 154 112
3 224 151
4 272 190
5 295 205
6 299 218
7 305 224
That engine those heads were on made 621HP @ 6600rpm and 541TQ @ 5100rpm this morning with the dominator.
Pump gas 414, solid roller cam, 10.9:1, TTI 1 7/8 x 3.5" header.
Brian
What are the cam specs? Did you do work on the intake?
I've seen very few tests with the dominator. Would be interested in the difference between it and an air gap.
I might need to bring mine back to you!
This is an all out pump gas engine on a "budget"! It ain't much for street driving.
Intake was ported decently, and the 1000HP did well against the dommy for sure.
With no tuning it made 601 at 6800rpm from the get go. Best with the OOTB 1000HP was 608, best with the PC 1000Hp was 615.
Cam was in the 260's @ .050 and lift was mid 600's.
wow any chance of getting pics of those full ported RHS heads that are ported as much as they can. Love to see those and flow numbers if possible
lift intake exhaust
1 70 52
2 154 112
3 224 151
4 272 190
5 295 205
6 299 218
7 305 224
Brian
With mufflers too... Sounded wicked cool
Very nice! Will have to give you a call when it comes time to rebuild my 340. Will be a ways off though.
Just out of curiousity Brian, what's a set of those done to that level go for? Those are great results.
Not cheap but if your running a solid roller you have to spend money on valvetrain no matter what you build.
Porting, valve job, surface cut, tubes, guide hone, cc chambers, assemble: about 1500.00.
That's actually quite reasonable. I'm still waiting on the guys who did mine to come tuck me into bed and kiss me good night for what they charged me.
