I’ve dealt with Jack Moore a lot of times. Located in Ohio.
Contact information? 65'
Sent Mr Moore a message. Thanks.
Justin, those pistons are 13.5:1 You building a race engine?
An early 71-74 360 block will work. Mine is a late '70. Bored .060, sonic tested good.4.060” bore and a 340 main.
So, you need a really nice 340 block that will clean up at a .020” overbore.
Or an aftermarket block.
And what do u do for main bearings? 360 crank has way bigger mains.An early 71-74 360 block will work. Mine is a late '70. Bored .060, sonic tested good.
Bearing spacer shims take the 360 bearing bore down to 340 size. Not real common but they are out there.And what do u do for main bearings? 360 crank has way bigger mains.
