Just wanted to know what you guys were using plug wise for a stock 70 340. Champion N-12Y came out of it but my book shows N-9Y for 69-72 340 N-12Y was not used until 1973.
Thanks for your comment. Champion web site even said to go with RN12YC. My old dealer catalog spec. N-9Y. Searches were not conclusive either.use rn9yc champions. that would be correct for a 68-71 340 application. if you use aluminum heads, edelbrock recommends rn12yc.
How did these colder plugs perform? Any fouling? Thank you.I used to run N6Y and N7Y's in my 68 340 back in the 70's-Don't ask me why, I just did.
for what i remember, the j series spark-plugs from champion are for big-blocks.My Motors Manual specifies J12Y Champion plugs for 1962 & later, long before elec ign came along.
A lot of engines would be running better if they used the hotter spark plug that the factory specified.
I remember the 340 ran hard, but the plugs only lasted 5-6000 miles. But they were cheap and everywhere, and it seemed no one else used these two numbers. Used to get them from Farm stores, Wheelers, Tractor Supply and such. Most of them were 99 cents a piece.
I have and still do use the N-9y plugs (when I can find them) in my 69-70, 340's. The "R" are for the radio interference and the "C" is for copper. I have heard that the resister "R" plugs, fail often. I run copper spark plug wires and copper dist. caps , so why not use "C" (copper) plugs. They work well for me. The last plug change I did had over 60,000 miles on them. Setting the gaps correctly are important, as well as the points. Always install a new condenser when changing the points, it prolongs the points.Thanks everyone for their input. Good information. Just want to get this build completed. Need to make an engine run stand out of my engine cradle so need to move forward. Will go with the N-9YC. Have factory manifolds so install with either size plug should not be an issue.
Thanks for your comments. Went with the copper variety of the N9Y. Did not get the resistor plug for my radio does not work.I have and still do use the N-9y plugs (when I can find them) in my 69-70, 340's. The "R" are for the radio interference and the "C" is for copper. I have heard that the resister "R" plugs, fail often. I run copper spark plug wires and copper dist. caps , so why not use "C" (copper) plugs. They work well for me. The last plug change I did had over 60,000 miles on them. Setting the gaps correctly are important, as well as the points. Always install a new condenser when changing the points, it prolongs the points.
