Spark Plug & Wire combo Suggestions
rod locker
Needing wires with a 45 or 90 degree boot. I have straight boots on now and on the driver side they are realy hafd to connect because of the exhaust manifold. Looking also to change out plugs. What combo do ya'll run in a '74 318 with a 4 barrel. Will also be changing manifold to Performer and a blaster II coil.
I am running Denso Plugs in my 340 and using Accel Wires (Some with 90 deg boots) So far I have not had any issues with this combo.
i running cheapo autolite plugs for now and will be getting magnecor wires. i'll probably switch plugs to ngk's after motor break in.
