1. limegreen70
    limegreen70 Pokorny Enterprise's
    1,540
    285
    Apr 27, 2014
    Milton PA
    Local Time:
    3:47 AM
    What Tooth Speedo gear do I need for a 3:91 rear, 26'' tall tire car?
  2. Professor Fate
    Professor Fate Push the button, Max...
    1,669
    2159
    Jan 13, 2020
    Wisconsin
    Local Time:
    3:47 AM
    • Like Like x 2
    • limegreen70
      1,540
      285
      Apr 27, 2014
      Milton PA
      Local Time:
      3:47 AM
    • limegreen70
      1,540
      285
      Apr 27, 2014
      Milton PA
      Local Time:
      3:47 AM
      Quick question. What size wrench does the nut take that takes the speedo cable off the 727? Looks like it might be a 15/16. Biggest wrench i have is a 7/8.
    • Ricks70Duster340
      Ricks70Duster340 Child of the King, widower FABO Gold Member
      200
      95
      Feb 8, 2021
      Sisterdale, TX
      Local Time:
      3:47 AM
      Believe it is a 1". I use a large adjustable wrench on mine.
      • Agree Agree x 1
      • toolmanmike
        toolmanmike FABO MODERATOR Staff Member FABO Gold Member
        58,721
        46144
        Jan 18, 2006
        Iowa
        Local Time:
        3:47 AM
        Now is when I miss the tool truck in the driveway. I had a set of stubby wrenches that work great for this kind of stuff.
      • Ricks70Duster340
        200
        95
        Feb 8, 2021
        Sisterdale, TX
        Local Time:
        3:47 AM
        Tool trucks are evil because they always cause us to see another tool that would be great for this or that! That's why when we are older we look at our array of tools and wonder how we ever did that!!!
        • Agree Agree x 1
        • toolmanmike
          58,721
          46144
          Jan 18, 2006
          Iowa
          Local Time:
          3:47 AM
          Exactly, by design. It was a fun ride for almost 30 years.
          • Like Like x 2
          • limegreen70
            1,540
            285
            Apr 27, 2014
            Milton PA
            Local Time:
            3:47 AM
            It never occured about a stubby wrench! I tried a crescent and channel locks. Both are to big and hit the crossmemeber.
          • TrailBeast
            TrailBeast AKA Mopars4us on Youtube
            21,675
            9479
            Mar 11, 2011
            Arizona
            Local Time:
            1:47 AM
            If you only tighten that nut by hand you will never have that problem.
            There is zero reason it needs to be wrench tight.
            • Agree Agree x 1
            • limegreen70
              1,540
              285
              Apr 27, 2014
              Milton PA
              Local Time:
              3:47 AM
              I wasn't the one who installed it so it is wrench tight. I notice rtv around that area so I think that is where my 727 leak is coming from and while I am at it, I figured I put the proper speedo gear in it to.
            • Ricks70Duster340
              200
              95
              Feb 8, 2021
              Sisterdale, TX
              Local Time:
              3:47 AM
              Mine leaked too. It is likely the speedo gear pinion seal. I got a new o-ring for the speedo housing & smaller black seal for the speedo pinion from ebay. Fixed my problem.
              • Agree Agree x 1
              • TrailBeast
                21,675
                9479
                Mar 11, 2011
                Arizona
                Local Time:
                1:47 AM
                Gotcha.
                I use just a thin film of rtv where the large O ring around the housing contacts the trans case.
                It’s not enough to see from the outside.
                Hopefully who did yours was just a little rtv happy and there isn’t some issue they were trying to fix.
              • TrailBeast
                21,675
                9479
                Mar 11, 2011
                Arizona
                Local Time:
                1:47 AM
                You can even put 2 of those small seals in there.
                It fixes a speedo gear shaft groove problem.
              • Ricks70Duster340
                200
                95
                Feb 8, 2021
                Sisterdale, TX
                Local Time:
                3:47 AM
                I've seen leaks where whoever put in the pinion seal did not fit it all the way into the recessed area before putting the metal retaining clip on. When they pushed the speedo gear in, it shifted the seal and a leak occurred. I've never had to use RTV to cover a seal leak on the housing. Simply put on fresh seals & applied a little dielectric grease (vaseline would work too) to the seal & pinion shaft. When inserting the gear into the housing, slowly insert it while turning it to keep the seal from moving out of place.
                • Agree Agree x 1
                • limegreen70
                  1,540
                  285
                  Apr 27, 2014
                  Milton PA
                  Local Time:
                  3:47 AM
                  My thinking is. The seals are original and when they started to leak, rtv was just put around the outside instead of changing the seals. I could be wrong though, we shall see. I Just hope like hell it stops the majority of the leaks. I am so sick of atf everywhere.
                • Ricks70Duster340
                  200
                  95
                  Feb 8, 2021
                  Sisterdale, TX
                  Local Time:
                  3:47 AM
                  Yeah, getting our older cars to stop leaking is an ongoing problem! When I got my car this past November, I found the gas tank leaked when I filled it full. When I got it home, I found the old owner put RTV type stuff all around the filler tank grommet to try to stop the leak. Guess it was too much work to simply change the grommet! I pulled the grommet, scraped all the "pookie" off around the tank opening, and installed a new grommet. Lubed the filler tube and reinstalled it. No more leaks. Funny!
                  • Like Like x 1
                  • toolmanmike
                    58,721
                    46144
                    Jan 18, 2006
                    Iowa
                    Local Time:
                    3:47 AM
                    :lol: New/soft rubber seals and fresh gaskets can do wonders.
                    • Agree Agree x 1
                    • limegreen70
                      1,540
                      285
                      Apr 27, 2014
                      Milton PA
                      Local Time:
                      3:47 AM
                      people are lazy. But I understand that some people dont have the physical ability or even the cash to do a proper fix so they jerry rig it. But I cant have bad work on my conscious so I always try and do the job right.
                    • Ricks70Duster340
                      200
                      95
                      Feb 8, 2021
                      Sisterdale, TX
                      Local Time:
                      3:47 AM
                      Amen!
                    • TrailBeast
                      21,675
                      9479
                      Mar 11, 2011
                      Arizona
                      Local Time:
                      1:47 AM
                      I hear ya on the leaks, they annoy me too.
                      Who knows though, as they could have tried to fix it and trashed the gear from not putting it back together with housing in the correct orientation.
                      Maybe just smearing rtv on it was a blessing.:D
                    • limegreen70
                      1,540
                      285
                      Apr 27, 2014
                      Milton PA
                      Local Time:
                      3:47 AM
                      So the gear I have is a 41 but I need a 40. Does a extra tooth make that much of a difference in mph?
